Shinyboat
Feb 21, 2021Tutor
R6400v2 Choppy Calls & Some Devices No Connection
My router is about 3 years old. Since COVID, I have been working at home and noticed I have choppy audio in/out on Teams calls on approximately 1 of every 10-20 calls. I have run speed tests while bad...
Feb 22, 2021Guru - Experienced User
Does it happen if you're hardwired into the router?
The goal is to determine if its a wireless issue, a router issue, or just a teams issue.
What firmware are you on?
What modem/gateway is it connected to?
