brucecgirton
Mar 27, 2023Aspirant
R6400v2 connected printer does not show up on list of attached devices, and is slow or unreliable
This router is now several years old, so you'd think the bugs in the firmware would all have been worked out. Nonetheless, as I sit here, I have a new printer that often seems to lose connectivity d...
Mar 27, 2023Guru - Experienced User
Have you tried simply setting the printer with a reserved IP address?
One of the problems with 2.4ghz is it has more things that can interfere with the signal so also make sure you're on a channel with the least interference.
