brucecgirton
Mar 27, 2023Aspirant
R6400v2 connected printer does not show up on list of attached devices, and is slow or unreliable
This router is now several years old, so you'd think the bugs in the firmware would all have been worked out. Nonetheless, as I sit here, I have a new printer that often seems to lose connectivity d...
michaelkenward
Mar 28, 2023Guru - Experienced User
brucecgirton wrote:
I'm thinking the problem may have been caused by a firmware update, but I have no way to diagnose the problem or correct it.
And the current firmware version is? Please don't say "the latest". As often as not it isn't, thanks to quirks in Netgear's checking system. Only the number helps.
On diagnosis, have you looked at the router's logs? Have you checked that QoS is turned off?
