danheinz1126
Oct 24, 2021Aspirant
R6400v2 creating bottleneck
just had comcast out and we were trying to troubleshoot my connection. I pay for 1200 down and suddenly I was only getting 200. I had did some troubleshooting factory reset of router and restarting m...
- Oct 25, 2021
After doing quite a bit of reading in this forum of old threads the consensus was to roll back to 1.0.2.52_1.0.39
all the firmwares are found here https://www.netgear.com/support/product/r6400v2.aspx#download
It did help to get much faster speeds for me also tried the fresh tomato firmware but it didnt seem to help me but it did completely wipe all my settings and I was 100% sure nothing was carried over in any way. If you want to try it out it can be found here. https://freshtomato.org/downloads/freshtomato-arm/2020/2020.2/Netgear%20R-series%20initial%20files/
cscott1
Oct 24, 2021Guide
Yeah I have the same service with Xfinity and the same issue with the 6400v2 downgraded the firmware which helped get more speed but ultimately bought a new router the Rax50 to keep up with the speeds much happier now.
- danheinz1126Oct 24, 2021AspirantHave you seen why? Everything I saw showed it should be supports and it did work for awhile.
