ianskelley's avatar
ianskelley
Follower
Jan 12, 2023
R6400V2 DATA USAGE BY DEVICE
Hello,
I have a R6400V2.
I have been searching the community to find out if I can get usage stats on data used per device.
It seems like this is a feature not available on my router.
Is that correct?
If so, is there any other solution to get data usage per device info?
Thank you.
1 Reply
  • plemans's avatar
    You're correct, it isn't an option. Its one of the most requested features for quite a while in the ideas exchange for home.
    Your best bet if you want device tracking?
    Buy a device that supports it and connect the netgear to it in access point mode.
