drakkai
Feb 25, 2022Aspirant
R6400v2 Firmware Version 1.0.4.120 DNS problem
Hi, another update in a row, this time with version 1.0.4.120 (1.0.4.120_10.0.91), does not fix the DNS problem (DNS_PROBE_FINISHED_NXDOMAIN). There are many threads on the forum reporting this probl...
- Feb 25, 2022
Netgear has set up a community forum specifically for Smart WiFi Router products. Most of the people who watch that forum are more likely to have experience with General and Smart Wifi (WN and R6000 thru R6400 Series) routers. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
Feb 26, 2022Guru - Experienced User
some of the issues with dns were resolved when users enabled ipv6 and/or tried a different dns provider like googles at 8.8.8.8 or 8.8.4.4.
did you try those methods?
- drakkaiFeb 26, 2022Aspirant
Yes, I did. Nothing helped in both the current version and the previous ones. The only option is the rollback to the old firmware version 1.0.4.106_10.0.80
