drakkai
Feb 26, 2022Aspirant
R6400v2 Firmware Version 1.0.4.120 DNS problem
Hi, another update in a row, this time with version 1.0.4.120 (1.0.4.120_10.0.91), does not fix the DNS problem (DNS_PROBE_FINISHED_NXDOMAIN). There are many threads on the forum reporting this probl...
- Mar 30, 2022
For me, the solution to the problem was update to version V1.0.4.126_10.0.102. I got help from Netgear support with my case. For others looking for a solution to a similar problem, you can download the update here: https://kb.netgear.com/000064642/R6400v2-Firmware-Version-1-0-4-126 Strange things is that my router did not offer an upgrade to this version, I had to do a manual update.
drakkai
Mar 01, 2022Aspirant
Yes, I tried. As well as other proposed solutions in similar threads. It only helps to rollback to the old version 1.0.4.106 :/
Mar 01, 2022Guru - Experienced User
- drakkaiMar 11, 2022Aspirant
What is Mfr? The model of ISP modem is compal ch7465lg-lc (set to bridge mode).
The problem is with firmware, affected are all versions newer than 1.0.4.106_10.0.80. Resolving domains works randomly - once it works correctly, and otherwise it claims that the page cannot be found (the address is correct) and only refreshing it a few times helps. If I set DNS server addresses manually in the browser/OS, the domain resolution is working fine - the problem is that I can't do it everywhere and not on all devices. If you search the forum here, you will find a lot of threads with a similar problem for different devices, eg. https://community.netgear.com/t5/General-WiFi-Routers-Non/Latest-update-bug-R6400-Firmware-DNS-issue-V1-0-1-74-1-0-48/td-p/2125726
- FURRYe38Mar 11, 2022Guru - Experienced User
So downgrade FW to what had been working. NG will have to fix this as this is not something beyond forum help.
