drakkai
Feb 26, 2022Aspirant
R6400v2 Firmware Version 1.0.4.120 DNS problem
Hi, another update in a row, this time with version 1.0.4.120 (1.0.4.120_10.0.91), does not fix the DNS problem (DNS_PROBE_FINISHED_NXDOMAIN). There are many threads on the forum reporting this probl...
- Mar 30, 2022
For me, the solution to the problem was update to version V1.0.4.126_10.0.102. I got help from Netgear support with my case. For others looking for a solution to a similar problem, you can download the update here: https://kb.netgear.com/000064642/R6400v2-Firmware-Version-1-0-4-126 Strange things is that my router did not offer an upgrade to this version, I had to do a manual update.
drakkai
Mar 30, 2022Aspirant
- michaelkenwardMar 30, 2022Guru - Experienced User
That happens from time to time. I have an R7000P struck in the same position.
It is one reason why some of us prefer the manual route.
The "check for updates" option is unreliable.
