stripey_cat
Nov 22, 2021Aspirant
R6400v2 intermittent internet issues after firmware upgrade
I've seen a few posts about this but no satisfactory resolution. After upgrading firmware to v1.0.4.120_10.0.91, internet connectivity/DNS resolution becomes spotty. Often for a site I know is valid...
Nov 22, 2021Guru - Experienced User
We've seen it across multiple products lines. Not just yours.
Some were able to enable IPv6 and it worked fine. Did you try that?
stripey_cat
Nov 23, 2021Aspirant
Are you talking about enabling it on the router, or the individual connected devices? If it's the latter, that isn't really a workable solution as there are are several, of all different OSes, and some come and go (e.g. friends, new devices, etc.) What I really want to know is if NetGear is aware of this,and is a fix forthcoming.
- plemansNov 23, 2021Guru - Experienced User
Yes, enable it in the router.
I've a feeling netgear is aware of the issue.
No idea on when they plan on fixing it as they don't talk to us a whole lot :)
