stripey_cat
Nov 22, 2021Aspirant
R6400v2 intermittent internet issues after firmware upgrade
I've seen a few posts about this but no satisfactory resolution. After upgrading firmware to v1.0.4.120_10.0.91, internet connectivity/DNS resolution becomes spotty. Often for a site I know is valid...
charmcgee
Nov 28, 2021Aspirant
I am having similar issues and I am just a regular housewife so no technical background here. All I know is I did a manual upgrade 2 days ago and nothing runs right. Intermittent internet issues all day long. My dashboard for the router now suddenly says I am in Access Point mode and I changed nothing! It also says there are 11 attached devices, which should be correct, but when I go to look at the devices attached it only shows one. Driving me crazy!
- michaelkenwardNov 29, 2021Guru - Experienced User
Dashboard? Is that the browser graphical user interface (GUI)?
A router won't magically go into AP mode. To get out of that reset the thing:
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
...when I go to look at the devices attached it only shows one.
Where are you looking for that?
It might help if you told us what the modem is, if there is one, in front of the router. That should have been one of the first questions.
