derekul
Mar 18, 2024Follower
r6400v2 lates update
what is the latest firmware updare for the r6400.v2 ?
Mar 19, 2024Guru - Experienced User
Located here:
https://www.netgear.com/support/product/r6400v2#download
- seant1Apr 28, 2024Aspirant
Says there is a virus on it so windows will not allow us to download it.
- FURRYe38Apr 28, 2024Guru - Experienced User
I just downloaded it to my WIndows 11 PC. No virus detected.
Try a different PC or temporary disable your virus progream long enough to download the .zip file.
Windows defender blocks it. Have to go in to protection history to allow it. Comes up as a trojan....only this specific patch does.
Also, Netgear check your patches for this router. It has a major issue making people revert back to a woefully outdated firmware to get the advertised speeds.
