derekul
Mar 18, 2024Follower
r6400v2 lates update
what is the latest firmware updare for the r6400.v2 ?
seant1
Apr 28, 2024Aspirant
Says there is a virus on it so windows will not allow us to download it.
Apr 28, 2024Guru - Experienced User
I just downloaded it to my WIndows 11 PC. No virus detected.
Try a different PC or temporary disable your virus progream long enough to download the .zip file.
- seant1Apr 28, 2024Aspirant
Windows defender blocks it. Have to go in to protection history to allow it. Comes up as a trojan....only this specific patch does.
Also, Netgear check your patches for this router. It has a major issue making people revert back to a woefully outdated firmware to get the advertised speeds.
- FURRYe38Apr 28, 2024Guru - Experienced User
Checked clear on my PC.
This router is EoL so maybe time to get something newer.
Good Luck.
