Sab505
Apr 15, 2020Tutor
R6400v2 loses all connectivity but all lights flash normal
Hello, my problem is that every few days, my R6400v2 loses all internet connectivity, both wired and wireless, but the lights on the router all continue to blink/flash as normal, indicating traffic i...
- Apr 15, 2020
You can try installing firmware version 1.0.3.66 to the router, factory reset it, and manually reinstall it. Then disable auto updates. The versions after that have netgear armor and some R6400 users have reported issues with it.
If that doesnt fix it, then you would want to make sure its the router and not the modem.
Apr 15, 2020Guru - Experienced User
What arris cable modem is it?
What firmware is on the router?
the hard part is that its tough to determine if its the router or the modem. An easy check is to hardwire into the modem and use it for a while. If you're connection is dropping daily and you can stay running directly off the modem for that period, its probably not the modem
