Sab505's avatar
Sab505
Tutor
Apr 15, 2020
R6400v2 loses all connectivity but all lights flash normal
Hello, my problem is that every few days, my R6400v2 loses all internet connectivity, both wired and wireless, but the lights on the router all continue to blink/flash as normal, indicating traffic i...
  • plemans's avatar
    Apr 15, 2020
    You can try installing firmware version 1.0.3.66 to the router, factory reset it, and manually reinstall it. Then disable auto updates. The versions after that have netgear armor and some R6400 users have reported issues with it.
    If that doesnt fix it, then you would want to make sure its the router and not the modem.
