Sab505
Apr 15, 2020Tutor
R6400v2 loses all connectivity but all lights flash normal
Hello, my problem is that every few days, my R6400v2 loses all internet connectivity, both wired and wireless, but the lights on the router all continue to blink/flash as normal, indicating traffic i...
- Apr 15, 2020
You can try installing firmware version 1.0.3.66 to the router, factory reset it, and manually reinstall it. Then disable auto updates. The versions after that have netgear armor and some R6400 users have reported issues with it.
If that doesnt fix it, then you would want to make sure its the router and not the modem.
Sab505
Apr 15, 2020Tutor
The Arris cable modem is an SB8200,
The router firmware version is V1.0.4.84_10.0.58 (should be the latest)
Running directly from the modem is a great idea, unfortunately it drops maybe once or twice a week, and between me and my spouse and the kids, we have a plethora of devices that need to be connected to the internet, and my spouse also needs privacy when conducting video conferencing (therapist), so she can't be hanging out by the cable modem when working. (sad face)
Thank you!
Sab505
Apr 15, 2020Tutor
Also, I should have mentioned that the R6400v2 was recently purchased (1-2 months ago) and the previous wifi router (Belkin N450 DB) never had to be rebooted.
- plemansApr 15, 2020Guru - Experienced User
