PeterVN
Apr 22, 2023Aspirant
R6400v2: Multicast IPTV & Internet?
Hi All, I have been using Netgear R6400 and not using a modem provided by my ISP. When Enable VLAN/Bridge and I can see IPTV in my Tivi but my Tivi can't connect to Internet. If Disable VLAN...
PeterVN
michaelkenward wrote:
PeterVN wrote:Hi All,
Which modem are you using? There has to be something between the R6400 and the Internet?
Why did you do that? What is this "tivi"?
Can anything connect to the Internet?
Before I used a router from My ISP. From My Sony Tivi connected to Router via LAN and My Sony Tivi can connected to Internet and watched Tivi via UDP IPTV.
When I changed to Netgear (Optical->Converter->Netgear (by PPPoE)), I don't know how to configure Multicast in LAN for Internet and UDP IPTV together.
michaelkenward
Apr 22, 2023Guru - Experienced User
How is the R6400v2 router connected to the Internet?
What is this Optical->Converter->? A modem? An optical network termination
(ONT)?
What is this Sony Tivi? I cannot find anything with that name in Google. At least not in English, the language we use here.
Do you mean Sony TV?
- PeterVNApr 25, 2023Aspirant
PeterVN wrote:When I changed to Netgear (Optical->Converter->Netgear (by PPPoE)), I don't know how to configure Multicast in LAN for Internet and UDP IPTV together.
(ONT)?
Before I used a router from My ISP. From My Sony Tivi connected to Router via LAN and My Sony Tivi can connected to Internet and watched Tivi via UDP IPTV.What is this Sony Tivi? I cannot find anything with that name in Google. At least not in English, the language we use here.
R6400 Connected to Internet as the picture as follows:
Yes, Sony Tivi is Android Sony TV
- michaelkenwardApr 25, 2023Guru - Experienced User
Unfortunately, that picture does not tell me what that box on the left is. It looks like a cable modem.
Is there a label on it with a model number? Something like this:
Without full details of what you have, it is impossible to diagnose any problems that you see.
michaelkenward wrote:Unfortunately, that picture does not tell me what that box on the left is. It looks like a cable modem.
the box on the left is the Gigabit Fiber Media Converter similar as the picture below
