EFG588
Aug 25, 2022Aspirant
R6400v2 Multiple Odd Disconnections (New Thread)
R6400v2 Firmware - V1.0.4.128_10.0.104 Small Business Workloads >10-12 connected devices >3 Devices on static routes >.2 - .10 reversed for Address Res Table >NAS (LAN) and 2 printers (Wifi) >...
michaelkenward
Aug 26, 2022Guru - Experienced User
I'm having a hard time working out what the problem is here.
Take this:
EFG588 wrote:
>Can connect, but no internet connection (internet connection is fine) -
What does it mean?
What "can connect"?
What says "no internet connection"?
Do you actually have an Internet connection?
You have provided lots of useful details of what is on your network, but the description of problems is a bit terse.
No control over modem, as its tied into our building contract. Its either on a VM VPN network, or a VPN network.
Those local networks can be a pain to understand.There aren't many people her familiar with that sort of network.
Buildings sometimes come with a central router. So bolting another router on to them can cause grief.
Anyone have a fix, or know if the recent firmware is bugged, or is the router dying. 1 year of use.
It should die that young. There are various things that you can try, starting with a factory reset and fresh installation.
You can also roll back to earlier firmware. If that fixes it, then your theory about bugged firmware might hold.
I don't recall seeing a pile of similar complaints about new firmware on this router. Other issues maybe:
- Sassybug13Sep 18, 2022Aspirant
I am having the same issue. Router wifi connections are being lost every 3-4 days. Hard wired connections are fine but wifi must have power reset to device to get it working again.
My only thought is firmware upgrade so I am going to check on if it can be dropped back down. But this is jumping up and down on my very last nerve. TIA for any assistance or suggestions.
