smv24
Aug 02, 2023Follower
R6400v2 Power Adapter
Does anyone know the part number for the power adapter that goes with the R6400v2 router? I recently moved and have several NETGEAR power adapters and want to make sure I use the correct one. Thanks!...
Kitsap
Aug 02, 2023Master
smv24 wrote:Does anyone know the part number for the power adapter that goes with the R6400v2 router? I recently moved and have several NETGEAR power adapters and want to make sure I use the correct one. Thanks!
Check the back of your R6400v2 where the power cord connects. It should show the voltage and current requirements for the device. Use the adapter the matches those values.
