smv24
Aug 02, 2023Follower
R6400v2 Power Adapter
Does anyone know the part number for the power adapter that goes with the R6400v2 router? I recently moved and have several NETGEAR power adapters and want to make sure I use the correct one. Thanks!...
michaelkenward
Aug 03, 2023Guru - Experienced User
Netgear does not sell replacement power adapters in most markets. Any generic transformer will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions. (Look at the label on your device or the old adapter.)
The details you need should be on the old adapter, on a label on the device itself and in its manual.
You can find suitable adapters in all the usual on-line places. Some will even list compatibility with different Netgear hardware.
Some generic adapters come with a set of tips that will fit a range of different devices.
