Krycha00
Sep 22, 2022Aspirant
R6400v2 problem with 5ghz wifi
Hello, Wifi 5ghz is working only 50cm from the router, and event then signal is very bad. I tried hardware reset, different firmware etc. Nothing helped. Anyone has this problem? 2,4ghz is working ve...
Krycha00
About half of devices on my home was connected via 5ghz, and one day suddenly i got info on All od them "there is no wifi". I tried to connect different devices and everytime is the same - i have to put laptop/mobile next to the router (or even on router) to have any info about the 5ghz wifi. 1m from router there is no more signal.
Sep 22, 2022Guru - Experienced User
Have you tried changing the wifi channel?
Tried a factory reset?
Or even reinstalling the firmware, then doing a factory reset?
- wcalifasSep 24, 2022Prodigy
If you've tried different firmwares, doing a hard reset, and its still doing the same thing then the wifi radio on the 5ghz has gone bad.
