ggilson
Jan 05, 2022Tutor
R6400v2 router - app won't update firmware
The nighthawk app repeatedly gives me an error message when I try to update the firmware. The "download" for the firmware on the website gives me a document that my computer doesn't trust, and an...
michaelkenward
Jan 06, 2022Guru - Experienced User
ggilson wrote:
The "download" for the firmware on the website gives me a document that my computer doesn't trust, and an html link that sends me back to the same download link that gives me the same zip file...
What does that mean? In what way "does not trust"?
If you get the firmware from the Netgear site, it comes in a zip file with the firmware and release notes.
My firmware version is V.1.0.4.106 which is probably a few updates ago, but I think every time I try to update this is what happens, and I give up.
There have been three since then:
R6400v2 Firmware Version 1.0.4.122 | Answer | NETGEAR Support
- ggilsonJan 06, 2022Tutor
- plemansJan 06, 2022Guru - Experienced User
You don't "open" the file. Once its extracted, you follow the manual update process and upload it to the router.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
You know, I'm a person who uses a computer, not an engineer. First of all, the app should work. Second of all this should not be so hard.
When I got to routerlogin.net I get an error message.
