unicornb58
May 11, 2024Aspirant
R6400v2 router cannot update firmware
I have read several posts. My router web page does not offer a login. I only get a white blank page. I sweep the cursor over the page to see if the cursor ever changes and it does not. The page a...
unicornb58
May 12, 2024Aspirant
If I use chrome or ms edge I just get a blank white page. No data, just white screen. I tried firefox today and the result was still not successful. If I do it without internet then I get a error that it cannot file routerlogin.net if I do have internet from a different source (the netgear router has not internet as I am in a hotel and not at home. I get a different result but it cannot find a page it is looking for. In all cases there is never a login page. The router is a Netgear AC1750 Smart WiFi Router model R6400v2 and I have tried this with my personal HP notebook running Windows 10 and my work Dell also running Windows 10.
The power LED starts out dim but soon is bright AMBER and the port that I am connect to (I have tried 1-4 the same results) is bright WHITE. The port light blinks on occasion. After a while I will get the port light goes OFF and the next to the last light goes on then I get the 2.4 and 5G lights white; and the power LED goes from AMBER to WHITE but is always solid ON.
The AC power adapter is 12VDC @ 2.5A and is larger than the other adapters that i have. It appears to be OK since the lights on router seem to ack OK except that I never see the power LED blink which from the documents I have been able to locate is the sign that I can do a tftp to reflash the firmware.
michaelkenward
May 12, 2024Guru - Experienced User
That looks like typical boot-up sequence. No suggestion of bust firmware.
Have you started with the simplest move, a reset?
How to Reset Your NETGEAR Router Password - NETGEAR Blog
As this is an older router (2017), if that fails you could try this;
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
It isn't advised on newer routers with their different chips, but your "senior" device might respond to this move.
This is puzzling:
There's not much that you can do if you aren't sitting next to the router. Netgear disable Remote Management quite some time ago.
Why is the Remote Management feature being removed from NETGEAR routers? - NETGEAR Support
- unicornb58May 12, 2024Aspirant
I did a factory reset with the reset pb yesterday when I could not connect. It did change the IP address from something that had been set in the past for work back to the default of 192.168.1.1 but still cannot access the web page so no ability to log into the router for any configuration.
I have not been trying anything remote. I have a cable from a USB-> ethernet adapter from Trendnet (TUC-ETG) since my notebook does not have a copper network port internally. The Dell from work does and I have used the internal copper network connection there. I am running a short (7') cable from the pc to the router and have tried all 4 LAN ports on the router in case there was a problem with one of them but none of them give me access to any webpage to log into the router as described in the product manual.
