rgjacobsen
Feb 13, 2022Tutor
R6400v2 Router keeps dropping Internet Connection
R6400v2 Router keeps dropping Internet connection. Some days I have to reboot it twice or more. Weirdly enough, checking the Internet connection through the app always gives me the super fast connecti...
Feb 14, 2022Guru - Experienced User
1. what firmware is on the router?
2. what modem/gateway is it connected to?
3. did this just start? has it been going on a while?
4. does it happen to all devices? Just wireless devices? Just wired?
5. Is IPv6 enabled? (if not enable and reboot the router)
- rgjacobsenFeb 14, 2022TutorIt has the latest firmware version. I think this started after I installed it. The modem is an Arris SB6190, but if checking the Internet speed through the router’s app works, then I doubt it’s the modem. It also gets temporarily fixed after rebooting the router. I haven’t checked the wired devices, but all the wireless except TVs on Roku seem to get affected. IPv6 apparently comes disabled by default, I have just enabled it and set to use DHCP.
- plemansFeb 14, 2022Guru - Experienced User
"The latest version" isn't always the latest or there could be a version with issues. Its why we ask for an actual version number you're on.
did ipv6 help?
- rgjacobsenFeb 14, 2022TutorIt didn’t, it has just happened again. Firmware is v1.0.4.122_10.0.95, when I check for newer versions it says none is available.
