bray91
Sep 16, 2023Follower
R6400v2 seemingly limiting speeds for wired connections
I just upgraded my internet service to 500 Mbps. When I use a wired connection directly from the cable modem to my PC, I get ~550 Mbps on fast.com and on ookla speedtest. However, when I then plug the modem into my R6400v2 router and test speed again, I am only getting ~230 Mbps. Both tests were performed multiple times within about 5 minutes of one another with no other streaming or significant network activity.
The only custom setting I have on the router is assigning a static IP to another device on my network. I have downloaded and installed the latest firmware. What else should I be checking in terms of my router config to achieve better speed when using my wired connection into my router? Thanks!
1 Reply
When you changed your Internet service, did you run the router through the Internet setup wizard to change its settings to those of the new network?
