TimRashmawy
Oct 12, 2021Aspirant
r6400v2 slow wifi
I am experiencing very slow wifi speeds from my R6400v2. I have 500mbps download speed and get at least that while plugged into the LAN port on the router, but get much slower over wifi. Even standin...
Oct 12, 2021Guru - Experienced User
that R6400 isn't going to give you super fast speeds because its a pretty base model, gigabit device.
You can try changing what channels you're broadcasting on.
Or even try a factory reset and reinstall (make sure to leave, qos, access control, traffic monitoring, and parental controls all disabled).
- TimRashmawyOct 12, 2021Aspirant
I forgot to mention, that this is a relatively new issue I've been dealing with. I used to get excellent wifi speeds from it. I understand that the wifi speeds will be slower than LAN speeds, but I used to get around 450 from wifi anywhere in my house.
- michaelkenwardOct 13, 2021Guru - Experienced User
TimRashmawy wrote:
,,,,I used to get around 450 from wifi anywhere in my house.
You don't say what your wifi clients are but that smells more like a measurement issue than real wifi speeds.
Many devices won't do 450 Mbps, especially on 2.4 GHz, which is what you are likely to see at 30 feet away. The 60-70 Mbps you mentioned earlier sounds about right for many clients.
It might be worth a bit of background reading.
Understand Wi-Fi 4/5/6/6E (802.11 n/ac/ax) (duckware.com)
duckware knows their stuff and can bust a few myths and cut through marketing hype.
- plemansOct 13, 2021Guru - Experienced User
like michaelkenward says, i think thats a bit of misunderstanding of wifi.
The R6400v2 is/was a pretty base model gigabit AC device. It was never the fastest and 5ghz speeds drop off quickly.
I'd highly doubt the actual throughput was 450mbps anywhere in the home. Maybe ***Maybe*** (big maybe) right next to the router, but not with any distance/obstructions.
- TimRashmawyOct 13, 2021AspirantThe only reason I was testing the speeds is because recently, when downloading a 140mb file, it took more than 30 minutes. It also has been taking a long time for even web pages to load. I don’t particularly care about what my actual wifi speeds are, but it’s just annoying when we can’t watch Netflix without buffering or when I can’t download a relatively small file without it taking a very long time.
Do I just need a new router?
