Allah
Aug 25, 2021Aspirant
R6400v2 Speed issue
hi i created a topic about this back in 2019 and the issue still isnt resolved . my internet speed is 500/500 mbps , im able to get those speeds on the V1.0.3.66_10.0.50 software , but when i update ...
Allah
Aug 26, 2021Aspirant
with the latest firmware V1.0.4.118_10.0.90 my speeds have dropped from 500/500 to around 200/150 , on firmware version 1.0.3.66 i was getting 500 down and up , but ever since i updated the firmware im getting no more than 200 mbps . i've been having this issue for a while now. i tried rebooting and factory resetting the router .
michaelkenward
Aug 26, 2021Guru - Experienced User
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
- AllahAug 26, 2021Aspirant
im using a modem/ont provided to me by verizon fios
- michaelkenwardAug 26, 2021Guru - Experienced User
That just says you have a box on the wall. It tells us nothing about what it is and what it can do.
well assuming you know what a modem is and what it does , i have the verizon fios modem connected to the nighthawk router with a cat 5e ethernet cable. i don't know what else what you want me to include on here.
