Allah
Aug 25, 2021Aspirant
R6400v2 Speed issue
hi i created a topic about this back in 2019 and the issue still isnt resolved . my internet speed is 500/500 mbps , im able to get those speeds on the V1.0.3.66_10.0.50 software , but when i update ...
michaelkenward
Aug 26, 2021Guru - Experienced User
Allah wrote:
well assuming you know what a modem is and what it does
I sure do. I have owned many over the years.
But modems come in different flavours with a whole raft of possible features. Some do wifi, some do phones, some do handstands.
This will give you some idea of what we are up against:
verizon fios modem - Google Search
If you can find your modem, it probably has a label on the bottom that has a brand name and a model number. Without that information it is impossible to rule out some of the issues that can affect any router you attach to it.
Allah
Aug 26, 2021Aspirant
oh i see , well i cant flip the modem at the moment over to see if it has a model number since its on the wall , but the brand of the modem is verizon . if you search for verizon ont , you'll see it there . im just going to attach a photo i got off the internet , it looks exactly like the equipment i have.
