Allah
Aug 25, 2021Aspirant
R6400v2 Speed issue
hi i created a topic about this back in 2019 and the issue still isnt resolved . my internet speed is 500/500 mbps , im able to get those speeds on the V1.0.3.66_10.0.50 software , but when i update ...
scpal9
Jul 23, 2022Aspirant
I've had the same issue. Didn't matter what modem I had it wired to. I get 400 mbps from modem, but after.it goes through router the speed is capped at around 200 mbps. Router AC 1750 R6400v2. It is supposed to handle the speeds, but I see all over the internet the same issue.
michaelkenward
Jul 24, 2022Guru - Experienced User
scpal9 wrote:
..... I see all over the internet the same issue.
Got a link to some of these "all over the Internet" references? They might help us to understand what is going on, given that you haven't told us anything about your own circumstances.
You have joined in on an existing year old conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
