Piocze's avatar
Piocze
Tutor
Apr 27, 2022
R6400v2 timeouts under 5GHz load
Hi all,
I am using r6400v2 router with latest firmware. I performed factory reset after upgrading.
When I start using 5GHz network it would loose packets because of timeouts. 2.4GHz is a lot better.
What can I do to fix the issue?
  • plemans's avatar
    have you tried changing the channel its using? maybe there's interference.
    Do you have IPv6 enabled?
    What firmware did you install?
    What modem/gateway is it connected to?
    Did you have this issue before?
    • Piocze's avatar
      Piocze
      Tutor
      I am using 44 channel where, according to android app, is one more wifi running, so that should not be a problem. Changed to 56 without improvement.
      IPv6 disabled.
      V1.0.4.126_10.0.102 firmware.
      It's connected to ISP modem - GPON ONT H640G
      I believe that the issue was not as much noticeable before, but I often had issues with wifi.
      Strangely 2.4GHz/LAN network works as expected.
      My test is:
      - Keep ping 8.8.8.8 -t in the background
      - Start speedtest
      - Once speedtest starts there are Request timed out messages in the terminal
      - Once speedtest completes, there are no request timed out messages in terminal.
      • plemans's avatar
        try the 149+ channels. 56 is a dfs channel.
        did you try a factory reset?
