Retired_Member
Jan 26, 2023R6400V2 WHICH FIRMWARE Do I UPLOAD
I UPLOADED THE WRONG FIRMWARE To My ROUTER DOES ANYONE KNOW THE RIGHT ONE THANK YOU
- Jan 27, 2023
If you managed to force the wrong firmware on to the router, you may have bust it.
The router usually stops you from doing that.
What dies he power LED look like?
As Kitsap suggests, a manual update is the safest.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Kitsap
Jan 26, 2023Master
Retired_Member wrote:I UPLOADED THE WRONG FIRMWARE To My ROUTER DOES ANYONE KNOW THE RIGHT ONE THANK YOU
Off with the cap-lock key, no need to shout. Go to the Downloads section above and feed in the model number of your router.
The result takes you here: https://www.netgear.com/support/download/?model=R6400v2
Strongly recommend your use a manual update method like described here: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Avoid automatic updates or updates via an application on a mobile device.
