Retired_Member
Jan 26, 2023R6400V2 WHICH FIRMWARE Do I UPLOAD
I UPLOADED THE WRONG FIRMWARE To My ROUTER DOES ANYONE KNOW THE RIGHT ONE THANK YOU
- Jan 27, 2023
If you managed to force the wrong firmware on to the router, you may have bust it.
The router usually stops you from doing that.
What dies he power LED look like?
As Kitsap suggests, a manual update is the safest.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
michaelkenward
Jan 27, 2023Guru - Experienced User
