Retired_Member
Jan 26, 2023R6400V2 WHICH FIRMWARE Do I UPLOAD
I UPLOADED THE WRONG FIRMWARE To My ROUTER DOES ANYONE KNOW THE RIGHT ONE THANK YOU
- Jan 27, 2023
If you managed to force the wrong firmware on to the router, you may have bust it.
The router usually stops you from doing that.
What dies he power LED look like?
As Kitsap suggests, a manual update is the safest.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
michaelkenward
Jan 27, 2023Guru - Experienced User
Retired_Member
Jan 27, 2023It's great now thank you
- michaelkenwardJan 27, 2023Guru - Experienced User
Retired_Member wrote:
It's great now thank youGlad it worked.
Which bit worked for you?
Mark that as SOLVED and you could help someone else who turns up here with the same question.
- Retired_MemberJan 27, 2023I don't know what bit is
- microchip8Jan 27, 2023Master
He meant which part worked for you...
