Bryansnell
Aug 17, 2018Aspirant
R6700 Firmware update problem
Downloaded the nighthawk iPhone app, installed my R6700 router, everything working fine, app said to update firmware, I said ok, 50 minute later and app still says its updating and to not turn off the...
- Aug 17, 2018
> [...] app still says [...]
I'd forget the apps, and stick with the web browser -- less
(unreliable) Netgear software that way.
> [...] 50 minute later [...]
https://community.netgear.com/t5/x/x/m-p/1618755
After you try to restart the thing, if it does not behave as desired,
then report the states of the LED indicators in the next installment.
antinode
Aug 17, 2018Guru
Bryansnell
Thanks for the replies. I went ahead and pressed the reset button and this time I skipped the firmware update step. Up and running now and I will do the update later through a browser. Thanks again.
- michaelkenwardAug 18, 2018Guru - Experienced User
Bryansnell wrote:
....I will do the update later through a browser.Wise move.
Even the browser can cause problems if you allow it to update "automagically".Many users prefer to download the firmware and update it from the local file.
The release notes explain what to do:
