abredt
Sep 12, 2017Aspirant
R6700 Wirelessly and Wired at the Same Time
I have an R6700 Router connected to my desktop computer wirelessly and want to update the firmware with a wired connection. Can I just connect the wires or must I disable the wireless connection?...
- Sep 13, 2017
Sorry for the omissions. Yes - Windows 10 Dell Desktop.
I logged into the router and there was a line that said there is a firmware update available. I clicked on it expecting more info, but it went ahead and did the update. Crazy !!
Thanks for your reply.
cb
antinode
Sep 12, 2017Guru
> [...] my desktop computer [...]
Based on the complete lack of information about "my desktop
computer", should we assume that it's running some version of Windows?
> How would I disable the wireless connection?
Connecting an Ethernet cable would be a good start. Windows should
handle most of the details. You may want to disable the wireless
network temporarily. Isn't there a wireless-network icon in the tray at
the bottom right of your display? Otherwise, the Control Panel or
Settings panel should have some network-related capability.
abredt
Sep 13, 2017Aspirant
cb
