MHarrisEP
Jul 07, 2020Initiate
R6900P Wi-Fi Crash w/ Lenovo T480
Hello, I've been chasing a strange issue since I've been working from home in early March of this year. The basic summary is; if my work laptop (Lenovo T480) is connected to my home Wi-Fi net...
DarrenM
Jul 13, 2020Sr. NETGEAR Moderator
You could try to adjust the wireless channels to see if that helps. Also, make sure mumimo is enabled
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
Launch a web browser from a computer or mobile device that is connected to the network.
2. Enter http://www.routerlogin.net. Manage the WiFi Network Settings 145 Nighthawk AC1900 Smart WiFi Router Model R6900P A login window opens.
3. Enter the router user name and password. The user name is admin. The default password is password. The user name and password are case-sensitive. The BASIC Home page displays.
4. Select ADVANCED > Advanced Setup > Wireless Settings. The Wireless Settings page displays.
5. Scroll down below the WPS Settings section and clear the Enable MU-MIMO check box.
6. Click the Apply button. Your settings are saved. If you connected over WiFi to the network, you are disconnected from the network and must reconnect.
