PICKLERICK84
Nov 08, 2021Guide
R6900v2 lost internet connection
I lost internet connection (orange light) to my router (R6900v2) yesterday morning. First few cable modem (CM1200) reboots would solve the connection issue, but only for a few minutes. Called Comca...
- Nov 08, 2021Factory reset worked. Thank you, to all, for the help
PICKLERICK84
Nov 08, 2021Guide
I will try, although the cable is new and is of higher quality.
Next step, I am thinking, will be to factory reset the router and/or modem.
Nov 08, 2021Guru - Experienced User
I'm always a fan of a factory reset/reinstall. Sometimes fixes random problems.
- PICKLERICK84Nov 08, 2021GuideFactory reset worked. Thank you, to all, for the help
- michaelkenwardNov 09, 2021Guru - Experienced User
PICKLERICK84 wrote:
Factory reset worked. Thank you, to all, for the helpI seen no suggestion that you tried the less drastic recover move, which is to restart everything in the right order:
It may help to reboot the whole network in the right order.
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
If you didn't try that, it might be worth remembering for the next time this happens.
- FURRYe38Nov 09, 2021Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
