PICKLERICK84
Nov 08, 2021Guide
R6900v2 lost internet connection
I lost internet connection (orange light) to my router (R6900v2) yesterday morning. First few cable modem (CM1200) reboots would solve the connection issue, but only for a few minutes. Called Comca...
- Nov 09, 2021Factory reset worked. Thank you, to all, for the help
PICKLERICK84
Nov 09, 2021Guide
Nov 09, 2021Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
