badler's avatar
badler
R7000 port forwarding not workiing
Hi,   I have set several different port forwards and none of them work, the only port which seems accesible externally is 8080 for remote access.  I have read all the posts on this forum and cant f...
  • badler's avatar
    badler
    Jan 05, 2017
    Hi
    thanks for your reply.
    my ISP is not blocking port 9 (WOL) and even if I put the PC into the DMZ, it still does not receive the WOL packet via port forwarding.
    I am using a Cisco modem, not a modem/router so no place to change any settings.
    Any other ideas?
    Cheers
    Brendon.
