badler
Jan 05, 2017Aspirant
R7000 port forwarding not workiing
Hi, I have set several different port forwards and none of them work, the only port which seems accesible externally is 8080 for remote access. I have read all the posts on this forum and cant f...
- Jan 05, 2017
Hi
thanks for your reply.
my ISP is not blocking port 9 (WOL) and even if I put the PC into the DMZ, it still does not receive the WOL packet via port forwarding.
I am using a Cisco modem, not a modem/router so no place to change any settings.
Any other ideas?
Cheers
Brendon.
DexterJB
Jan 05, 2017NETGEAR Moderator
Hi badler,
1. If your router is connected to gateway/modem-router, make sure you have the ports forwarded there pointing to the router IP.
2. Try using DMZ for the LAN IP you are forwarding the ports to as an isolation step.
3. Check with your ISP to see if they are blocking any ports.
Dexter
Community Team
badler
Hi
Any other ideas?
Cheers
Brendon.
