brianm0122
Jan 17, 2021Aspirant
R7960 as a bridge
My setup:
C6900 as a modem/router/gateway
R7960P as an AP
R6400 as an AP
The 7960 is using a powerline adaptor for connection to the router. Performance/thruput is lacking. It is serving a TV and latency is over 300ms. Suspect there is horrible errors/jitter. I want to change this to a wireless bridge.
I am using the settings under the "advanced" menu. It will not connect to the gateway. no log messageson the gateway, so I don't know why.
Does anyone have a clue why this doesn't work? Does the C6900 support this function?
1 Reply
> R7960P as an AP
Firmware version? Connected to what?
> [...] It is serving a TV [...] I want to change this to a wireless
> bridge. [...]Your "a TV" has an Ethernet port?
> I am using the settings under the "advanced" menu. [...]
Not much meat on that bone.
> [...] Does the C6900 support this function?
I don't think that it's really a special function. To the main
router, I'd expect the router-as-bridge to look pretty much like any
other wireless client device. If all the radios are known to work, then
I'd wonder about the firmware in the router-as-bridge. I don't have an
R7960P, so I can't check anything here.
