gy1
May 09, 2017Aspirant
Random disconnects with N900 is this common?
So i'm trying to assist someone with this issue and i've seen other post / models with similar issues. Randomly the entire house internet will drop, the old netgear (i forget model) had logs for 'do...
- May 10, 2017
TX for the reply, i'm within 90 days of support from netgear so i called. They checked my settings and indicated it to be an ISP problem. My logs are stating 'dos attack syn/ack xx.xx.xx.xx ip address' As mentioned those are legit ip's of services i use. So with some 'enhanced monitoring' enabled by my ISP they noticed dropped connections and have since sent out a tech. He found something outside the house that thinks could be causing an issue, fixed and now its a wait and see.
If this does resolved for sure i'll repost and i hope this helps anyone else searching out 'netgear router / dos attacks from legit ip's'
ElaineM
May 10, 2017NETGEAR Employee Retired
Welcome to the community, @gy1
Will the connection drop if the computer is directly connected to the modem?
It's best to properly isolate as to whether which device is causing the problem.
Some users have reported that getting a new IP from the ISP solves their issue on dos attacks.
gy1
May 10, 2017Aspirant
