gy1's avatar
gy1
Random disconnects with N900 is this common?
So i'm trying to assist someone with this issue and i've seen other post / models with similar issues.  Randomly the entire house internet will drop, the old netgear (i forget model) had logs for 'do...
  • gy1's avatar
    gy1
    May 10, 2017
    TX for the reply, i'm within 90 days of support from netgear so i called.  They checked my settings and indicated it to be an ISP problem.  My logs are stating   'dos attack   syn/ack  xx.xx.xx.xx ip address'  As mentioned those are legit ip's of services i use.  So with some 'enhanced monitoring' enabled by my ISP they noticed dropped connections and have since sent out a tech.  He found something outside the house that thinks could be causing an issue, fixed and now its a wait and see.
    If this does resolved for sure i'll repost and i hope this helps anyone else searching out   'netgear router / dos attacks from legit ip's'
