PaulHass
Aug 21, 2018Aspirant
Random issues with C6300
Hi, this afternoon I experienced a weird issue with my Netgear router C6300. First I called Xfinity, but they ran various tests and said everything is perfect on their end. Here is my issue:
I...
- Aug 22, 2018
> I have several devices connected to the modem. [...]
All wireless connections? Visit http://netgear.com/support , put in
your model number, and look for Documentation. Get the User Manual.
What do the LED indicators on the modem+router indicate?
> [...] I reset the modem, [...]
What, exactly, does "reset" mean to you? (See "Factory Default
Settings" in the User Manual.)
antinode
Aug 22, 2018Guru
PaulHass
Aug 22, 2018Aspirant
I had to do reset factory and define new network then start connecting devices. Issue solved. Thanks.
