russgoff
May 11, 2020Aspirant
Randomly disconnects from the internet
We have a R6080 router installed. No modem. We lose internet connection randomly throughout the day and night. Goes offline for 1-3 minutes, then returns. Performance improves after a reboot, but ste...
- May 11, 2020
I'll go through the list, plemans, and thank you for taking the time to help me.
It's a new router, only a couple of months old, but we've been having these issues from the start and I realize that just because it's new doesn't mean it's faultless.
May 11, 2020Guru - Experienced User
russgoff wrote:I called the provider, who confirmed that there is no minirouter to contend with.
testing things is better than trusting phone support people.
If you're 100% sure of that then you've narrows it to:
1. the ethenet line running has issues. Try a new ethernet run and make sure its good and stable.
2. The firmware on the router is corrupt. You can try re-installing the firmware to it. A reset only removes settings, it doesn't overwrite firmware. which is were the re-install of the firmware comes in.
3. The hardware is bad. Try a old/backup router and see if it stays stable and works. If it experiences the same issues, then its not the router.
4. The wireless receiver/setup has issues. Again, try a different router if you've exhausted the other options. if it still has the issues, its the wireless receiver setup.
russgoff
