Yinzer1
Dec 15, 2020Star
Randomly disconnects WiFi throughout the day
I running the Nighthawk X6 R8000 WiFi router and it periodically drops signal throughout the day. I'm utilizing the smart connect feature, that I'm not too fond of. I also have a Nighthawk X6S Extend...
Dec 16, 2020Guru - Experienced User
You must have the R8000P not r8000 based off your firmware.
A couple things to try.
1. reinstall firmware version 1.4.1.42. factory reset the router and do a clean install. By clean i mean don't use a backup configuration. disable auto updates. The newer version got the netgear armor "upgrade". most devices played nicely with it but it seems like a few didn't.Maybe yours is one of those.
2. The EX8000 is a solid extender. the only thing I did with mine is during setup, i unchecked "extend 2.4gh". You can still use the 2.4ghz but it relies on the 5ghz for backhaul only. Usually if the 5ghz goes down, it drops back to the 2.4ghz as backhaul. But my area is horrible for 2.4ghz so I unchecked it so it wouldn't do that. Not sure if it'll help you but worth a chance.
I'd try doing those 2 and seeing how it works.
I'd also make sure not to use wan port aggregation. The SB8200 and the r8000p supports it but the sb8200 was known to have issues with wan port aggregation. so if using it, disable it.
Yinzer1
Dec 16, 2020Star
Thank you. I'll give it a try.
- plemansDec 16, 2020Guru - Experienced User
Let me know how it goes!
- Yinzer1Dec 17, 2020Star
I took your recommendation about removing the 2.4 from extender and everything is working fine now. No drops as of yet, it's been about 20 hours since the change. I didn't downgrade the firmware from the router as the issue was there prior to any firmware upgrades. I also noticed my wifi signal strength has been full bars as before it would flucuate.
But so far so good - thanks for the advice!
- Yinzer1Dec 30, 2020Star
Two week update - dropped wifi connection is back. When connected to an area where a router is located, it says I have full signal yet when I go to another floor I start to get notifications and emails. The lights on the Extender are stating that I'm online etc, but it appears that no data is reaching my devices, if that makes any sense. I'm using the Nighthawk X6 AC3200 with the Nighthawk X6S EX8000 - I know they are good equipment, but why can't I get them to have solid performance?
