Xando
Mar 19, 2020Tutor
Randomly getting Internet disconnected
Hi there! I've adquired recently the R6080 Netgear router, is got its lastest firmware 1.0.0.42. Thing is that it will constatly drop connection for no reason. I use mainly my computer which is wire...
- Mar 20, 2020
Xando wrote:I've checked on the documentation and on my modem's configuration and it's already got Bridge mode set and no NAT https://i.imgur.com/UGu66xb.png
I should mention that I've formerly used at least two other routers before with this modem and haven't had this particular issue.
I've seen several different brands of combo devices that didn't properly implement their bridge modde.
What I'd try for troubleshooting?
put the zyzel back in router mode but disable its wireless. Then run the netgear in AP mode. See if the problem still happens. If it does, it wasn't related to that. But if it doesn't, its an issue with how zyzel implements their bridge mode.
Xando
Mar 19, 2020Tutor
Reuploaded the firmware but the problem is still present, attached the log so you can see what I mean.
Mar 19, 2020Guru - Experienced User
your Zyxel P660ru-t1 also has an integrated router.
https://kb.netgear.com/30186/What-is-Double-NAT
that can cause issues
- XandoMar 19, 2020Tutor
- plemansMar 20, 2020Guru - Experienced User
- XandoMar 21, 2020TutorI checked more troughly the modem options and found another Bridge mode option, switched to that, but then it was after a few hours the problem was entirely gone, it's been almost a day since it got stable, nos a single disconnection. Made that did the trick, there's also a chance maybe it was my bandwitch all along due the quarantine situation, I installed the router the very same day it began. Who knows, anyways, it seems is all good now, thanks a lot for your assistance!
