Xando's avatar
Xando
Tutor
Mar 18, 2020
Randomly getting Internet disconnected
Hi there! I've adquired recently the R6080 Netgear router, is got its lastest firmware 1.0.0.42. Thing is that it will constatly drop connection for no reason. I use mainly my computer which is wire...
  • plemans's avatar
    Mar 20, 2020
    Xando wrote:
    I've checked on the documentation and on my modem's configuration and it's already got Bridge mode set and no NAT https://i.imgur.com/UGu66xb.png
    I should mention that I've formerly used at least two other routers before with this modem and haven't had this particular issue.
    I've seen several different brands of combo devices that didn't properly implement their bridge modde.
    What I'd try for troubleshooting?
    put the zyzel back in router mode but disable its wireless. Then run the netgear in AP mode. See if the problem still happens. If it does, it wasn't related to that. But if it doesn't, its an issue with how zyzel implements their bridge mode.
