mollusk
Oct 30, 2016Aspirant
Rangemax Wireless-N 150 Router wants static IP address during setup
I just dug out this router that I bought in 2010. I previously had dsl and did not need it, but am trying to setup comcast internet and use this router. I have tried to setup by using the CD and se...
- Oct 31, 2016
Thanks! I actually updated the firmware and it seemed like that did the trick.
TheEther
Oct 30, 2016Guru
No, it shouldn't make a difference. You can use Wi-Fi to configure the router.
Go to Basic Settings and make sure the following are set:
- Does your Internet connection require a login? No
- Internet IP address: Get Dynamically from ISP
If you make any changes, be sure to click Apply to save them. Then reboot the router for good measure while it is plugged into the modem. Log back in and confirm that the router has obtained an IP address from Comcast.
- molluskOct 30, 2016Aspirant
Thanks for the reply. I do have both of those settings set correctly, and have power cycled the router, but it still comes up as detecting a static IP.
connection.
- ElaineMOct 31, 2016NETGEAR Employee Retired
mollusk Disconnect the router first from the modem and have those two settings selected and once it's been saved reconnect the Ethernet cable between the router and the modem.
- molluskOct 31, 2016Aspirant
