rgr
Oct 27, 2021Tutor
RAX20 loses IPV^ connectivity several times daily
My RAX20 router is connected to Xfinity and loses IPV6 connectivity several times a day. I initially used auto-detect to get a IPV6 address, after which the IPV6 page indicated it was using DHCP. For a short time, everything tests fine on IPV6 sites, but then starts to fail.
The router should support IPV6 consistently once connected, but doesn't.
How can I fix this?
rgr wrote:
I'll repost in your recommended forum.
It wasn't really necessary – some of us are nimble enough to deal with generic issues that apply to many routers in this place – but here you go:
Re: RAX20 router loses IPV6 connectivity several t... - NETGEAR Communities – undefined
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6Be sure to include ISP modem/ONT brand and model#
Be sure to check with ISP IPv6 services to ensure ISP is servicing correctly.
Thank you.- rgrTutor
FURRYe38 wrote:Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
Thank you.- michaelkenwardGuru - Experienced User
