polidore
Aug 22, 2021Follower
RAX70 Problem with AP Mode (AX6600 Router)
After putting the router in AP mode with either a fixed IP address or dynamic IP address, the router can not be located at the specified address or DHCP range after reboot. I've wasted many hours tr...
- Aug 22, 2021
What router are you connecting it to?
Try factory resetting it. PUsh and hold reset for 7-15 seconds while powered on.
After you reset and reinstall it, when you put it in access point mode, leave the IP address info alone and let your primary router assign the IP address.
Then log into the primary router and look at its attached devices page (or equivelent). It should have the router listed and its ip address. You should be able to log in with that.
Aug 22, 2021Guru - Experienced User
